Autoua.net → Форум → Autoua форум →
Прошу о помощи ... потерял таблетку от иммобилайзера ...
Zbuk | старый писатель ****
5 июля 2004 в 18:49
Новую купил ... как ее прошить в мой иммобилайзер.
Иммобилайзер
Cheetah
Micropro Touch Key
IMMOBILISER CH334
Заранее благодарен.
пока наковырял, что можно программировать включением ...
[Re: Zbuk] 6 июля 2004 в 12:12
пока наковырял, что можно программировать включением-выключением зажигания ... вот если б еще мануал найти ...
производитель....
[Re: Zbuk] 6 июля 2004 в 12:28
http://www.cheetahauto.com/prod_detail.asp?PID=20&Cate_id=5&parent_id=0
CH334B-Touch Key Immobilizer
Introduction:
The "Micropro Touch Key" immobiliser is a high security automatic arming anti-theft system. During arm state, the system immobilise the vehicle through interrupting the power supply to 2 areas essential for starting up of vehicle (ie. starter, ignition system or fuel supply). Disarming the system is by using a technological advance electronic digital touch key. Each key is uniquely coded. The large number of code combinations, 1014, is a deterrence to code scanning. The requirement for the direct contact of touch key to its panel mount probe make code grabbing impossible. The touch key is made of stainless steel case, it is handy, small and durable. The tri-colour LED and buzzer provide indication of the state of the system. The circuit of the system is designed such that disconnection of its power supply will not allow the vehicle to be started.
Key Specifications/Special Features:
Two-way engine immobilization (e.g. Starter, Ignition Coil)
45amp heavy duty power relay (Siemens)
Anti-code scanning
Uses Dallas Key System
Hot wire prevention
Cables of similar appearance to prevent easy identification
Service mode
Override mode
LED/Buzzer for arm/disarm confirmation
Primary Competitive Advantages:
Reputation
Service
Experienced Technical Staff
Main Export Markets:
Worldwide
Safety/Quality Approvals Details:
TAS(Singapore)
ISO 9002(Worldwide)
Pimot(Poland)
PCT(Russia)
Smap | Достоевский ***
А может лучше к спецам ? Только нужно иметь (+)
[Re: Zbuk] 6 июля 2004 в 19:12
security code, к-рый идет в комплекте со всей документацией, когда покупаешь машину.
А где их взять??? Все, кому звонил, говорят одно - выкинь ..
[Re: Smap] 6 июля 2004 в 21:59
А где их взять??? Все, кому звонил, говорят одно - выкинь ...
И купи у нас новый …
УРА ... знаю!!!!
[Re: Zbuk] 9 июля 2004 в 12:16
Спасибо Kelvin/Manager с www.cheetahauto.com за мануал!!!
 AlMat, moderator, Amateur
0 користувачів і 26 що побажали залишитися невідомими читають цей форум.
Переглядів теми: 3693
